[GRASS-dev] font path question for Linux and Windows
William Kyngesburye woklist at kyngchaos.com
Fri May 4 00:21:47 EDT 2007
On May 3, 2007, at 11:10 PM, Paul Kelly wrote:
> Also I have a proposed modification to the script:
> Index: mkftcap
> RCS file: /home/grass/grassrepository/grass6/tools/mkftcap/mkftcap,v
> retrieving revision 1.6
> diff -u -r1.6 mkftcap
> --- mkftcap     3 May 2007 04:25:17 -0000       1.6
> +++ mkftcap     4 May 2007 03:51:37 -0000
> @@ -12,7 +12,7 @@
>              for ext in $exts ; do
>                  find "$dir" -type f -iname '*.'"$ext" -print \
>                      | sed 's!^\(.*\)/\(.*\)$!\2:\1/\2:utf-8:!' \
> -                    | sed 's/\.'"$ext"':/:/'
> +                    | sed 's/\.'"$ext"':/:/I'
>              done
>          fi
>      done
> This will case-insensitively match the filename extension when it's
> stripping it out to form the short name for the font at the start
> of the line - some files had the extension in capitals and it
> wasn't matching them. Not a big deal though - just looked a bit
> uglier. But maybe the I flag for case insensitive matching might
> not work with all versions of sed.
It's already been discussed (r.in.wms problem) that /I is a GNU
extension to sed.  OSX, at least, is BSD.  Don't know what to say
otherwise...
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"History is an illusion caused by the passage of time, and time is an
illusion caused by the passage of history."
- Hitchhiker's Guide to the Galaxy
