[GRASS-dev] Problem with font selection in gis.m on Windows
Paul Kelly paul-grass at stjohnspoint.co.uk
Fri May 4 12:06:05 EDT 2007
The recent talk of fonts on this list brought me to try out some stuff on
Windows. I discovered there's a font selector control in gis.m (Config
Menu-->Set default display font) but if I click the button to try and
change it to anything other than Romans I get the following error:
couldn't execute "uname": no such file or directory
     while executing
"exec uname -s"
     (procedure "Gm::SelectFont" line 7)
     invoked from within
"Gm::SelectFont"
     ("uplevel" body line 1)
     invoked from within
"uplevel \#0 $cmd"
     (procedure "Button::_release" line 18)
     invoked from within
"Button::_release .dispfont.fontopt2.b"
     (command bound to event)
Obviously trying to use the "uname" command (not available on native
Windows) is the bug, but looking closer at the code (line 537 onwards in
gui/tcltk/gis.m/gm.tcl) it seems the relevant part is trying to put
together directories to search for Freetype fonts in? Which
(a) shouldn't even be needed here as I have the stroke font radio button
in the dialog selected and don't even have GRASS compiled with Freetype
support and
(b) might possibly be being made redundant by Glynn's new script to
populate $GISBASE/etc/freetypecap?
Not sure what's the best way to fix this, taking into account those
points.
Paul
