[GRASS-dev] ps.map: raster always under vector map?
Mon May 7 10:15:51 EDT 2007
Glynn Clements wrote:
> It would be fairly straightforward to copy paper.h into the PS driver,
> and allow e.g. GRASS_PAPER=a4 to override GRASS_{WIDTH,HEIGHT}, as
> well as adding margins. Supporting rotation (i.e. landscape) would
> also be straightforward.
> I'll come up with a draft implementation today.
Done. The size/margins can be set via GRASS_PAPER, while
GRASS_LANDSCAPE=TRUE will rotate the output.
