[GRASS-dev] iconv a required dependency for using Freetype?
Glynn Clements
glynn at gclements.plus.com
Mon May 7 18:54:34 EDT 2007
Paul Kelly wrote:
> > Can d.font -l get rid of duplicates and alphabetize (better if it ignored
> > caps)? Or will I have to do that in the GUI?
> I think that is better handled at the time the font list file is
> generated.
Agreed.
Ideally, mkftcap would unique-ify duplicate names, although this isn't
easy to do in a shell script.
I'm not so sure that either mkftcap, "d.font -l" or the GUI should
sort the overall list. It may be better if mkftcap grouped fonts
according to the directory in which they reside, in which case, both
"d.font -l" and the GUI should preserve that ordering. Ditto if the
user manually re-orders the entries.
