[GRASS-dev] r.info cleanups
Hamish
hamish_nospam at yahoo.com
Tue May 8 04:42:17 EDT 2007
In CVS I have done some r.info cleanups.
* "print & exit" foo=bar command line options can now be combined.
G63> r.info roads -rt
min=1
max=5
datatype=CELL
* "Data Source:" is only printed if it exists (saves 4 lines in the
fancy output). If no "Comments:" the full info now fits in 80x25.
* Projection only prints out "(zone %d)" if proj is UTM. Note that the
projection and zone info comes from the current Location settings, not
.proj and .zone in the map's Cell_head structure! (if they don't match
you should get an error when you try to open the map)
Hamish
