[GRASS-dev] information regarding structure dglGraph_s of directed graph library
Nitin grasschoper at rediffmail.com
Wed May 9 07:01:25 EDT 2007
Hello everybody,I am trying to use graph generated by Vect_net_build_graph(), hold by  Map_info::graph.This element is of type dglGraph_s, having a typedef to type GRAPH.I want to access this graph structure. I couldn\'t understand this from syntax which is declared in lib/vector/dglib/graph.h .Also do i always need to specify cost  of arcs in database only?regardsjay
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20070509/d48bc827/attachment.html
