[GRASS-dev] [grass-code I][395] can't display raster maps
grass-codei at wald.intevation.org
Wed May 9 09:03:21 EDT 2007
code I item #395, was opened at 2007-05-09 13:03
Status: Open
Priority: 3
Submitted By: Jochen Gaedcke (gaedcke)
Assigned to: Nobody (None)
Summary: can't display raster maps
Issue type: module bug
Issue status: None
GRASS version: CVS HEAD
GRASS component: None
Operating system: Linux
Operating system version: SuSe 10.2
GRASS CVS checkout date, if applies (YYMMDD): 070509
Initial Comment:
Trying to display raster maps by gis-manager gives a white monitor.
Output Window shows no entries.
Synchronous display of a vector map does work, output is in that case either,
clicking "show aktive layers"-button:
g.pnmcomp in=31031.4.ppm mask=31031.4.pgm opacity=1.00 background=255:255:255 width=642 height=385 output=31031.1.ppm
Or, clicking "reload all layers" (don't know the real name while using the german version):
<button>d.rast map=PisteFotoRect at fluggelaende -o
PNG: GRASS_TRUECOLOR status: TRUE
PNG: collecting to file: /home/joc/Data/grassdata/FlugplatzAltdorf/fluggelaende/.tmp/linux-joc/31031.0.ppm,
GRASS_WIDTH=642, GRASS_HEIGHT=385
<button>d.vect map=sicherheitsstreifen at fluggelaende color=0:0:0 lcolor=0:0:0 fcolor=170:170:170 display=shape type=point,line,boundary,area icon=basic/circle size=5 layer=1 lsize=8 xref=left yref=center llayer=1
<button>g.pnmcomp in=31031.4.ppm mask=31031.4.pgm opacity=1.00 background=255:255:255 width=642 height=385 output=31031.1.ppm
If I try to display the maps using the terminal I get the following:
GRASS 6.3.cvs (location):~ > d.rast map=map at mapset -o
memory access error
Compiling showed errors in r.terraflow and v.in.dwg which had no effect on this in former versions.
Thanks for help
You can respond by visiting:
http://wald.intevation.org/tracker/?func=detail&atid=204&aid=395&group_id=21
