[GRASS-dev] Re: [bug #4924] (grass) missing quoted path vars in init.sh
Markus Neteler neteler at itc.it
Wed May 9 14:58:26 EDT 2007
cc grass-dev
http://intevation.de/rt/webrt?serial_num=4924
On Wed, May 09, 2007 at 01:00:44PM -0500, William Kyngesburye wrote:
> One more I found - line 843.  I quoted the echoed PROMPT_COMMAND for
> the bash shell to get it to work:
>     echo "PROMPT_COMMAND='$GISBASE/etc/prompt.sh'" >> "$bashrc"
> I had to use single-quotes to get it to work.  I tried escaped double-
> quotes but I still got path splitting errors.  I decided not to
> commit this myself, in case the single quotes cause other problems
> (that fine detail is beyond my shell knowledge).
Any opinions on this?
Markus
