[GRASS-dev] Re: Not universal building on Mac
Glynn Clements
glynn at gclements.plus.com
Wed May 9 15:17:30 EDT 2007
William Kyngesburye wrote:
> --with-opengl-libs=/usr/X11R6/lib should be the only option needed.
> Without it, the opengl checks might accidentally find the OSX version
> of the opengl libs, not the X11 version, and this may be what is
> confusing NVIZ and causing the crash.
I'm fairly sure that would result in a compile-time error due to
missing glX* symbols.
But, why would you want an X11 version of NVIZ on OSX?
