[GRASS-dev] iconv a required dependency for using Freetype?
Paul Kelly
paul-grass at stjohnspoint.co.uk
Thu May 10 12:33:22 EDT 2007
On Thu, 10 May 2007, Michael Barton wrote:
> In the GUI, I'm depending on d.font -l to supply font names in a valid
> format useable by GRASS_FONT. Is this still happening?
Yes. If I understood Glynn's message correctly, right now it isn't showing
the stroke fonts but probably will again soon.
> Whatever these names are, the gui will try to eliminate duplicates in the
> list supplied by d.font -l
Ideally that shouldn't be necessary if we can generate the list correctly.
But it may still be a while until we sort that out (cf. William's e-mail
of this morning with the apparently unexplainable identical copies of
fonts in the same file).
However at least, once we change d.font -l to use the new fontcap file it
should no longer be necessary/desirable to sort the list in the GUI.
Paul
