[GRASS-dev] iconv a required dependency for using Freetype?
William Kyngesburye
woklist at kyngchaos.com
Fri May 11 15:17:23 EDT 2007
On May 10, 2007, at 11:03 AM, Paul Kelly wrote:
>> One suggestion - make it useable outside of GRASS, or during the
>> startup process. (I tried it and got a segfault)
> It calls G_no_gisinit(), i.e. it doesn't require a valid location
> or mapset to be present, just GISBASE and GISRC to be set, so
> should be fine for most purposes I think.
Doesn't help if I want to generate the *cap file before init.sh is
run, since the user hasn't selected a map yet. I thought about
trying a dummy location like the demolocation, but that would have to
be installed with the binary.
I came up with this possibility - in init.sh, after it gets a valid
mapset from the user (and all the needed vars are set):
--- init.sh-orig 2007-05-11 13:58:54.000000000 -0500
+++ init.sh 2007-05-11 13:56:38.000000000 -0500
@@ -676,6 +676,15 @@
exit 1 ;;
esac
+if [ "$GRASS_FONT_CAP" ] && [ ! -f "$GRASS_FONT_CAP" ] ; then
+ echo "Building user fontcap ..."
+ g.mkfontcap -o
+fi
+if [ "$GRASS_FT_CAP" ] && [ ! -f "$GRASS_FT_CAP" ] ; then
+ echo "Building user freetypecap ..."
+ g.mkfontcap -o -f
+fi
trap "" 2 3 15
# cygwin has many problems with the shell setup
This should be safe - it should not get run on the *caps installed
with the GRASS binary (though if a user sets either to be the binary
copy, it will try to), but only when either or both env vars are set
and the file doesn't exist. It will give the user a start for adding
other fonts manually, or cleaning up possible mistakes.
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
[Trillian] What are you supposed to do WITH a maniacally depressed
robot?
[Marvin] You think you have problems? What are you supposed to do
if you ARE a maniacally depressed robot? No, don't try and answer,
I'm 50,000 times more intelligent than you and even I don't know the
answer...
- HitchHiker's Guide to the Galaxy
