[GRASS-dev] [bug #5185] (grass) shared libraries problem
(Solaris2.9/Sparc)
Paul Kelly
paul-grass at stjohnspoint.co.uk
Sat May 12 09:04:35 EDT 2007
On Sat, 12 May 2007, Markus Neteler wrote:
> On Sat, May 12, 2007 at 01:09:59PM +0100, Glynn Clements wrote:
>> Markus Neteler via RT wrote:
>>> https://intevation.de/rt/webrt?serial_num=5185
>>> RT wrote:
>>>> Sorry to say, but the problem persists. Did a CVS update today, and the
>>>> configure-script still sets include/Make/Platform.make:
>>>> SHLIB_LD = /usr/ccs/bin/ld -G -z text
>>>> which is not able to link anything during the compilation. When changed
>>>> to:
>>>> SHLIB_LD = CC -G -z text
>>>> compilation runs ok.
>>>> If I can provide you with some other related files etc. please let me
>>>> know.
>>>> Harri K.
>>> Any idea how to fix this?
>> Change lines 1158, 1207 of aclocal.m4.
> Is attached patch right? I wonder about CC version $CC. Have
> used $CC in the patch.
CC is the Solaris native C++ compiler I think. I see there is a separate
section in aclocal.m4 for building with GNU gcc on Solaris. I don't have
access to any machines using the native Solaris compilers to test it, but
I suppose it sounds reasonable. Seems weird to have to use the C++
compiler for linking when GRASS is almost all C though. Maybe Glynn is on
to something about GDAL. So many parts of GRASS indirectly depend on GDAL
now - I wonder though is there anything that links properly using the
Solaris ld?
Paul
