[GRASS-dev] [bug #5185] (grass) shared libraries problem (Solaris2.9/Sparc)
Markus Neteler neteler at itc.it
Sat May 12 11:14:39 EDT 2007
On Sat, May 12, 2007 at 03:18:35PM +0100, Glynn Clements wrote:
> Markus Neteler wrote:
> > Is attached patch right? I wonder about CC version $CC. Have
> > used $CC in the patch.
> It should be "CC"; that's the name of the C++ compiler.
OK, have used CC now.
On Sat, May 12, 2007 at 02:12:15PM +0100, Paul Kelly wrote:
> I would say only change it in the second location, as that covers Solaris
> 9 (i.e SunOS 5.9) and the other version applies to old versions of Solaris
> up to 2.6 (which is pretty old these days) and the issue might not apply
> there?
I have changed the second location only in aclocal.m4 and regenerated
configure. In CVS now.
Harri, could you please test if it now works?
Markus
