[GRASSGUI] wxgrass gui status: was [GRASS-dev] Vect_snap_lines
(list of lines)
Maciej Sieczka
tutey at o2.pl
Sun May 13 09:50:13 EDT 2007
Paul Kelly wrote:
> ISTR also somebody
> pointing out that the GUI menus tended to obscure which GRASS module it
> was you were actually running (of course it's visible when you open the
> auto-generated GUI dialog, but not from the GUI menus, in gis.m anyway)
That is not correct, if I understand what you mean. You *can* see the
command name without opening it - on gis.m's bottom panel, when you
highlight the command entry in the menu.
Maciek
