[GRASS-dev] Re: not quite there on fonts
Tue May 15 01:51:10 EDT 2007
Hamish:
> > ok, so bug #1977 still matters. (axes tags somewhat broken for FP
> > maps)
> >   http://intevation.de/rt/webrt?serial_num=1977
Michael:
> At least on my system this bug doesn't exist. Here is a screenshot of
> the new wxgrass histogram window for elevation.10m from Spearfish.
> Maybe it was fixed?
it only happens for some FP maps, for some window sizes.
try: (spearfish)
 d.mon x0
 d.histogram slope
then adjust the window size by grabbing the side of the frame.
rinse & repeat.
If I try that elevation.10m with a narrower window width the x units
disappear altogether.
from the bug report:
default for FP maps is to reduce to 255 cats as in r.stats, but the
calculation for tick spacing is using the FP range: conflict of units.
Hamish
