[GRASS-dev] v.dissolve fails with sqlite driver
Daniel Calvelo
dca.gis at gmail.com
Tue May 15 16:56:46 EDT 2007
Try to run v.dissolve with a 'set -x' to see whether v.extract or
v.reclass is to blame. A hunch could be an unique constraint not
satisfied in the index creation.
Daniel.
On 5/15/07, Markus Neteler <neteler at itc.it> wrote:
> Hi,
> so far the SQLite driver worked fine for me (after the various fixes) but it
> fails
> for v.dissolve with a problem which I don't understand:
> # Spearfish, create new "sqlite" mapset:
> db.connect driver=sqlite
> database='$GISDBASE/$LOCATION_NAME/$MAPSET/sqlite.db'
> g.copy vect=quads at neteler,myquads --o
> v.db.connect -p myquads
> # add table with char column:
> v.db.addtable myquads col="name varchar(10)"
> # populate with something
> v.db.update myquads col=name val="hello"
> v.db.select myquads
> # dissolved based on varchar column:
> v.dissolve myquads out=myquads_diss col=name
> DBMI-SQLite driver error:
> Cannot step:
> SQL logic error or missing database
> ERROR: Cannot fetch dataa
> Going into details:
> g.gisenv set=DEBUG=3
> D3/3: db_start_driver_open_database():
> drvname = sqlite, dbname =
> /home/neteler/grassdata/spearfish60/sqlite/sqlite.db
> D2/3: opendir
> /home/neteler/soft/63grass_cvsexp/dist.i686-pc-linux-gnu/driver/db/
> D3/3:
> db_driver_open_database()
> D3/3: name = '/home/neteler/grassdata/spearfish60/sqlite/sqlite.db'
> D2/3: name2 = '/home/neteler/grassdata/spearfish60/sqlite/sqlite.db'
> D3/3: SQL: SELECT cat, name FROM myquads ORDER BY name
> D3/3: Escaped SQL: SELECT cat, name FROM myquads ORDER BY name
> D3/3: describe_table()
> D3/3: ncols = 2
> D3/3: litetype = 1
> D3/3: litetype = 3
> D3/3: nkcols = 2
> D3/3: litetype = 1
> D2/3: col: cat, nkcols 0, litetype : 1, sqltype 3
> D3/3: litetype = 3
> D2/3: col: name, nkcols 1, litetype : 3, sqltype 13
> D3/3: 2 rows selected
> D3/3: key type = 15
> D3/3: execute: create table myquads_9293 (cat integer, name varchar(255))
> D3/3: db__create_index()
> D3/3: SQL: create unique index myquads_9293_cat on myquads_9293 ( cat )
> D3/3: fetch row = -1
> Cannot step:
> D3/3: Mapset = sqlite
> The problem is in db/drivers/sqlite/fetch.c
> Any ideas?
> thanks,
> Makus
> View this message in context: http://www.nabble.com/v.dissolve-fails-with-sqlite-driver-tf3760326.html#a10628682
> Sent from the Grass - Dev mailing list archive at Nabble.com.
> grass-dev mailing list
> grass-dev at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass-dev
-- Daniel Calvelo Aros
