[GRASS-dev] Re: [GRASSGUI] Re: [grass-addons] r659 -
trunk/grassaddons/gui/gui_modules
Glynn Clements
glynn at gclements.plus.com
Wed May 16 13:11:09 EDT 2007
Michael Barton wrote:
> Are you thinking that we should change all calls to GRASS commands to use
> the new cmd module?
> > + cmdString = "g.region -ugp region=%s" % wind
> > + p = cmd.Command (cmdString)
This interface is broken, and needs to be replaced.
self.module = subprocess.Popen(self.cmd, shell=True,
Wrong. Wrong. Wrong. Wrong. Wrong. Wrong. Wrong. Wrong. Wrong.
Just how clearly do I have to say this before it sinks in:
DO NOT USE THE SHELL
Using the shell means problems with spaces, quotes and other shell
metacharacters. There is no reason to use it. So don't.
