[GRASS-dev] v.dissolve fails with sqlite driver
Markus Neteler
neteler at itc.it
Fri May 18 05:52:41 EDT 2007
This bug was kindly fixed by my colleague Antonio Galea...
The sqlite3_reset was wrongly positioned (see
http://www.sqlite.org/capi3ref.html#sqlite3_step )
Cheers
Markus
Markus Neteler wrote:
> It is v.reclass which fails:
> + v.reclass input=myquads output=myquads_18985 layer=1 column=name
> DBMI-SQLite driver error:
> Cannot step:
> SQL logic error or missing database
> FEHLER: Cannot fetch data
> + v.extract -d input=myquads_18985 output=myquads_diss type=area layer=1
View this message in context: http://www.nabble.com/v.dissolve-fails-with-sqlite-driver-tf3760326.html#a10679257
Sent from the Grass - Dev mailing list archive at Nabble.com.
