[GRASS-dev] new tests on wxgui
Michael Barton michael.barton at asu.edu
Fri May 18 11:48:05 EDT 2007
Carlos,
Here are a couple solutions.
On 5/18/07 4:10 AM, "Carlos "Guâno" Grohmann" <carlos.grohmann at gmail.com>
wrote:
> OK, looking good.
> a few things:
> zoom to map still doesn't work for me. output msg:
> GRASS 6.3.cvs (itarare_250k):~ > Traceback (most recent call last):
>   File "/usr/local/grass-6.3.cvs/etc/wx/gui_modules/mapdisp.py", line
> 843, in ZoomToMap
>     for item in dcmd.split(' '):
> AttributeError: 'list' object has no attribute 'split'
I just fixed this. Another casualty of the change in command syntax from
string to list. There will probably be yet more of these.
> still can't change a raster map by double-clicking in its name and
> changing it to another raster in properties.
Do you get any error messages?
> In g.region dialog, when you click Run, the dialog goes to the Output
> tab, but there's no message, just the blank space, so maybe it could
> stay in the tab I was?
Does it work OK and just not say anything? g.region usually does not give
any output. Or does it not work?
> Oh, the gui-rastanalyze.gif icon does not exists.
You need to update from the cvs. That is where the icons live.
Michael
> nice work!
Thanks. I think we're getting there.
Have you tried out the new measure tool?
Michael
> On 5/18/07, Michael Barton <michael.barton at asu.edu> wrote:
>> I made the properties dialogs non-modal again. So the apply buttons work
>> now. If a properties dialog is launched from the gis manager (i.e.,
>> associated with a map layer), it will be automatically closed if that layer
>> is deleted (including drag and drop).
>> Michael
>> On 5/13/07 3:57 AM, "Carlos "Guâno" Grohmann" <carlos.grohmann at gmail.com>
>> wrote:
>>> Apply button - Why? when you ask for a new map (say raster), you get a
>>> window for d.rast, where you choose the map, the you have three
>>> options: "Cancel" "Apply" and "OK". The "Apply" does nothing. It will
>>> put the map name on GIS Manager, but that's all. You can't keep d.rast
>>> window open and draw the map on the display, you can't do nothing
>>> until you hit the "OK" button. So way keep this "Apply" button?
>>> "Cancel" and "OK" are all we need. (This "Apply" thing is way too much
>>> MSWindows IMO).
>>> I also couldn't change the raster map, with "Apply" or with "OK". I
>>> have to add a new one.
>> __________________________________________
>> Michael Barton, Professor of Anthropology
>> School of Human Evolution & Social Change
>> Center for Social Dynamics & Complexity
>> Arizona State University
>> phone: 480-965-6213
>> fax: 480-965-7671
>> www: http://www.public.asu.edu/~cmbarton
phone: 480-965-6213
fax: 480-965-7671
