[GRASS-dev] What to do after make...
Daniel Calvelo
dca.gis at gmail.com
Sat May 19 00:18:01 EDT 2007
Prameet,
Can you run grass as
# ./bin.i386-pc-solaris2.10/grass63
Daniel.
On 5/18/07, Prameet Chhabra - Sun Microsystems - Newark United States
<Prameet.Chhabra at sun.com> wrote:
> I am trying to build grass in Solaris and looks like make goes through
> without any errors... but make install says try make first..
> ans help will be appreciated
> bash-3.00# make
> test -d /usr/local/grass-6.2.1 || mkdir -p -m 755 /usr/local/grass-6.2.1
> tar cBf - demolocation | (cd /usr/local/grass-6.2.1/ ; tar xBfo - )
> 2>/dev/null
> chmod 744 install-sh
> `lib' is up to date.
> `db' is up to date.
> `display' is up to date.
> `doc' is up to date.
> `gem' is up to date.
> `general' is up to date.
> `gui' is up to date.
> `imagery' is up to date.
> `misc' is up to date.
> `paint' is up to date.
> `ps' is up to date.
> `raster' is up to date.
> `raster3d' is up to date.
> `scripts' is up to date.
> `sites' is up to date.
> `tools' is up to date.
> `vector' is up to date.
> `visualization' is up to date.
> `man' is up to date.
> if [ 1 -eq 1 ] ; then make locale; fi
> `locale' is up to date.
> cp -f AUTHORS COPYING README REQUIREMENTS.html /usr/local/grass-6.2.1/
> #cp -f /usr/local/bin/grass62 /usr/local/grass-6.2.1/grass62.tmp
> cat: cannot open ../dist.i386-pc-solaris2.10/etc/VERSIONNUMBER
> build_html_index.sh
> *.*.html: No such file or directory
> Generating HTML manual pages index (help system)...
> Generated HTML docs in ../dist.i386-pc-solaris2.10/docs/html/index.html
> Following modules are missing the 'description.html' file in src code:
> GRASS GIS compilation log
> Started compilation: Fri May 18 09:56:34 PDT 2007
> Errors in:
> Finished compilation: Fri May 18 09:56:34 PDT 2007
> (In case of errors please change into the directory with error and run
> 'make')
> bash-3.00#make install
> echo /usr/local/bin/grass62
> ERROR: GRASS has not been compiled. Try "make" first.
> Installation aborted, exiting Make.
> bash-3.00#
> grass-dev mailing list
> grass-dev at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass-dev
-- Daniel Calvelo Aros
