[GRASS-dev] Re: gis.m: font selection in module panels
Glynn Clements
glynn at gclements.plus.com
Mon May 21 14:31:05 EDT 2007
Michael Barton wrote:
> Normally, either GRASS_FONT has been set or it hasn't. It probably won't be
> set to "". How is the best way to determine if it has been set or not?
Try to use it and catch any errors.
If the following fails:
if {[info exists env(GRASS_FONT)] && $env(GRASS_FONT) != ""} {
then omitting the second half and using just:
if {[info exists env(GRASS_FONT)]} {
will presumably fail at the point that $env(GRASS_FONT) is used, for
the same reasons.
