[GRASS-dev] v.build on a broken vector -> coor files of vector is larger than it should be
Maciej Sieczka tutey at o2.pl
Mon May 21 14:46:57 EDT 2007
Maciej Sieczka wrote:
> Agustin Diez Castillo wrote:
>> v.build map=ACas260207b at adiez2 option=build
>> and not results, well yes those:
>> coor files of vector 'ACas260207b at adiez2' is larger than it should be
>> (15145471 bytes excess).
> This problem can be solved if you just open the vector in v.digit and
> quit. That will fix the vector.
BTW - does anybody know why this trick is actually needed? Why does
v.build output a coor file larger than necessary?
Maciek
