[GRASS-dev] GRASS and QGIS on Win32, testing etc.
Glynn Clements
glynn at gclements.plus.com
Mon May 21 15:11:49 EDT 2007
Moritz Lennert wrote:
> This also means that any shell scripts (e.g. g.mremove, v.dissolve, etc)
> will either have to be replaced by C-versions (which kind of defeats
> their purpose of being easily codable for a larger number), be coded in
> a cross-platform scripting language (e.g. Python), or anyone who wants
> to use these under Windows has to provide access to a series of shell
> tools (e.g. through Msys).
Personally, I would favour switching to Python.
Apart from the portability issues, both Bourne shell and C shell are
*really* poor as general-purpose programming languages.
If you just want to run a sequence of commands, then a shell saves you
the trouble of having to quote the arguments and prefix the command
with an "exec" (or similar) command, as would normally be the case for
a normal programming language.
As soon as you get beyond that, the fact that they were designed as
interactive shells first and programming languages second starts to
become a major problem.
