[GRASS-dev] GEM Wizard question
William Kyngesburye
woklist at kyngchaos.com
Wed May 23 10:21:11 EDT 2007
I believe $HOME is one of those automatic env vars that doesn't show
up in the env itself. Try:
echo "$HOME"
On May 23, 2007, at 8:53 AM, Gerald Nelson wrote:
> As far as I can tell (using the command env) there is no variable
> that looks like grass home on my system. Jerry
> ---- Original message ----
>> Date: Wed, 23 May 2007 08:45:09 -0500
>> From: William Kyngesburye <woklist at kyngchaos.com>
>> Subject: Re: [GRASS-dev] GEM Wizard question
>> To: Michael Barton <michael.barton at asu.edu>
>> Cc: Hamish <hamish_nospam at yahoo.com>, grass-dev at grass.itc.it
>> Is that from within GRASS, or other shell use? Which platform? If
>> GRASS needs HOME as Hamish says, then it won't run without it (or not
>> run right), so G_home() will always work. Unless maybe the GRASS
>> libraries are used outside of GRASS, like in Qgis or GDAL.
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
"Those people who most want to rule people are, ipso-facto, those
least suited to do it."
- A rule of the universe, from the HitchHiker's Guide to the Galaxy
