[GRASS-dev] r.in.gdal slow with input of type=UInt16
Jachym Cepicky
jachym.cepicky at gmail.com
Fri May 25 01:40:33 EDT 2007
when I try to import map, which was previously exported using r.out.gdal
type=UInt16, it takes too long:
GRASS 6.3.cvs (spearfish60):~ > g.region -dp
projection: 1 (UTM)
zone: 13
datum: nad27
ellipsoid: clark66
north: 4928010
south: 4913700
west: 589980
east: 609000
nsres: 30
ewres: 30
rows: 477
cols: 634
cells: 302418
GRASS 6.3.cvs (spearfish60):~ > r.out.gdal in=soils out=/tmp/soils.tif
type=UInt16
100%
r.out.gdal hotovo.
GRASS 6.3.cvs (spearfish60):~ > time r.in.gdal in=/tmp/soils.tif -o
out=tmp --o
100%
real 0m42.631s
user 0m41.239s
sys 0m0.120s
type=UInt32
ERROR 6: SetColorTable() only supported for Byte or UInt16 bands in
TIFF format.
100%
r.out.gdal hotovo.
out=tmp --o
100%
real 0m0.327s
user 0m0.192s
sys 0m0.064s
strace r.in.gdal in=/tmp/soils.tif out=tmp --o
access("/home/jachym/grassdata/spearfish60/jachym/cell/tmp", F_OK) = 0
access("/home/jachym/grassdata/spearfish60/jachym/fcell/tmp", F_OK) =
-1 ENOENT (No such file or directory)
access("/home/jachym/grassdata/spearfish60/jachym/g3dcell/tmp", F_OK)
= -1 ENOENT (No such file or directory)
write(10, "# 54 categories\n\n\n0.00 0.00 0.00"..., 38) = 38
close(10) = 0
munmap(0xb5b31000, 4096) = 0
access("/home/jachym/grassdata/spearfish60/jachym/cell_misc/tmp/histo
gram", F_OK) = -1 ENOENT (No such file or directory) time(NULL)
= 1180021981
access("/home/jachym/grassdata/spearfish60/jachym/hist", F_OK) = 0
creat("/home/jachym/grassdata/spearfish60/jachym/hist/tmp", 0666) = 10
close(10) = 0
open("/home/jachym/grassdata/spearfish60/jachym/hist/tmp", O_WRONLY) =
10
fcntl64(10, F_GETFL) = 0x1 (flags O_WRONLY)
fstat64(10, {st_mode=S_IFREG|0644, st_size=0, ...}) = 0
mmap2(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1,
0) = 0xb5b31000
_llseek(10, 0, [0], SEEK_CUR) = 0
write(10, "Thu May 24 17:53:01 2007\ntmp\njac"..., 121) = 121
close(10) = 0
brk(0x81f3000) = 0x81f3000
brk(0x8214000) = 0x8214000
brk(0x8235000) = 0x8235000
brk(0x8256000) = 0x8256000
brk(0x8277000) = 0x8277000
brk(0x8298000) = 0x8298000
brk(0x82b9000) = 0x82b9000
brk(0x82da000) = 0x82da000
brk(0x82fb000) = 0x82fb000
brk(0x831c000) = 0x831c000
brk(0x833d000) = 0x833d000
brk(0x835e000) = 0x835e000
brk(0x837f000) = 0x837f000
brk(0x83a0000) = 0x83a0000
brk(0x83c1000) = 0x83c1000
brk(0x83e2000) = 0x83e2000
brk(0x8403000) = 0x8403000
brk(0x8424000) = 0x8424000
brk(0x8445000) = 0x8445000
access("/home/jachym/grassdata/spearfish60/jachym/colr2/jachym/tmp",
access("/home/jachym/grassdata/spearfish60/jachym/colr", F_OK) = 0
creat("/home/jachym/grassdata/spearfish60/jachym/colr/tmp", 0666) = 10
close(10) = 0
open("/home/jachym/grassdata/spearfish60/jachym/colr/tmp", O_WRONLY) =
10
0) = 0xb5b31000
write(10, "% 0 65535\n0:122:43:136\n1:33:70:7"..., 4096) = 4096
write(10, "9:0\n620:0\n621:0\n622:0\n623:0\n624:"..., 4096) = 4096
write(10, "\n1259:0\n1260:0\n1261:0\n1262:0\n126"..., 4096) = 4096
write(10, "1844:0\n1845:0\n1846:0\n1847:0\n1848"..., 4096) = 4096
While "brk(brk(0x8445000) = 0x8445000)",
processor is on 100% and this is the place, where it takes so long.
Anybody could give me some advice?
Thanks
Jachym
Jachym Cepicky
e-mail: jachym.cepicky at gmail.com
URL: http://les-ejk.cz
GPG: http://www.les-ejk.cz/pgp/jachym_cepicky-gpg.pub
Name: not available
Desc: Toto je =?UTF-8?Q?digit=C3=A1ln=C4=9B?=
=?ISO-8859-1?Q?_podepsan=E1?= =?UTF-8?Q?_=C4=8D=C3=A1st?=
=?ISO-8859-1?Q?_zpr=E1vy?=
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20070525/682e5fe8/attachment.bin
