[GRASS-dev] [bug #2969] can wxPython GUI handle order of options for v.type and alike?
Maciej Sieczka tutey at o2.pl
Sun May 27 17:03:29 EDT 2007
Hamish wrote:
> I have added conditionalized GRASS 7 code to v.type in CVS to make it
> use to= and from= lists instead of type=,,,. It seems to work ok, but
> deactivated to avoid breaking the GRASS 6 module interface. In the mean
> time we have v.type.sh from the GUI now. Functionality would be lost in
> that you could only convert one feature pair at a time.
Is:
$ v.type from=point to=centroid; v.type from=line to=boundary;
as fast as:
$ v.type type=point,centroid,line,boundary
> v.clean tool-order from the GUI is still an issue. Only GUI solution I
> can think of is to suggest typing in the command at the gronsole prompt,
> as the order can be arbitrary.
Maciek
