[GRASS-dev] Re: nviz raster volume segfault
Hamish
hamish_nospam at yahoo.com
Mon May 28 06:12:06 EDT 2007
Hamish wrote:
> Bug #4725 http://intevation.de/rt/webrt?serial_num=4725
vox50 3d raster is here:
http://grass.gdf-hannover.de/wiki/Help_with_3D#Examples
But more tests show that this happens in the same place on startup even
with the no-opt "-q" quick flag.
G63> gdb $GISBASE/etc/nviz2.2/nviz
(gdb) run -f $GISBASE/etc/nviz2.2/scripts/nviz2.2_script -q
Starting program: /usr/local/src/grass/grass63/dist.i686-pc-linux-gnu/etc/nviz2.2/nviz -f $GISBASE/etc/nviz2.2/scripts/nviz2.2_script -q
[Thread debugging using libthread_db enabled]
[New Thread 16384 (LWP 18821)]
Program received signal SIGFPE, Arithmetic exception.
[Switching to Thread 16384 (LWP 18821)]
(gdb) frame 12
#12 0x08063e7b in Togl_CreateWindow (tkwin=0x8121690, parent=44040220, instanceData=0x81217a8)
at togl.c:1947
1947 togl->GlCtx = glXCreateContext(dpy, visinfo, None, directCtx);
So not volume= specific!
Hamish
