[GRASS-dev] native winGRASS pre-alpha testers needed
Moritz Lennert mlennert at club.worldonline.be
Tue May 29 04:57:45 EDT 2007
On 28/05/07 18:24, Markus Neteler wrote:
> Moritz Lennert wrote on 05/25/2007 10:44 AM:
>> On 24/05/07 18:36, Markus Neteler wrote:
>>> On Thu, May 24, 2007 at 06:10:46PM +0200, Moritz Lennert wrote:
>>>> On 24/05/07 17:35, Paolo Cavallini wrote:
>>>>> -----BEGIN PGP SIGNED MESSAGE-----
>>>>> Hash: SHA1
>>>>> Markus Neteler ha scritto:
>>>>>> - DBF access failed (r.to.vect in our case; this we really need to
>>>>>> fix)
>>>> Could you be a bit more specific about what failed how ?
>>> They wanted to use r.to.vect to convert [r.]watershed basins to
>>> vector polygons. Doing so, r.to.vect was whining about DBF. I don't
>>> have the detailed error message since it wasn't my machine - sorry.
>>> Maybe you/someone could try r.watershed + r.to.vect?
>> r.watershed elevation=elevation.dem at PERMANENT threshold=100
>> basin=basins stream=streams half.basin=half_basins visual=watershed_vis
>> r.to.vect input=streams at user1 output=streams feature=line
>> works perfectly for me.
>> The same for
>> r.to.vect input=basinsuser1 output=basins feature=area
>> If you (or the people who did the tests) can provide more details, I
>> could try again.
> The person doing the testing is probably already on a different
> continent now :)
> I remember (now) that they used "gis.m" to do r.watershed and r.to.vect.
Same here.
> Now I have no longer access to MS-Vista.
Neither do I...
Moritz
