[GRASS-dev] trying to test error trapping for invalid
Agustin Diez Castillo
Agustin.Diez at uv.es
Wed May 30 06:25:51 EDT 2007
With two days ago cvs universal installer (built with William's
instructions on iMac macintel) on iMac G5 ppc.
I got
access: No such file or directory
ERROR: LOCATION << //Users/Shared/grassdata/prueba_usuario >> not
available
GRASS GUI should be tcltk
But the gui is showing up, so I can choose the correct option.
If I recall right, this didn't happen before and the only way I was
able to start grass was changing the gui to text.
If I point to an inexistent gisdbase I got a warning on both the
terminal and the gui, but grass starts
ERROR: LOCATION << //Users/Shared/grassdata9/prueba_usuario_Gore >> not
available
Starting GRASS ...
After accepting the warning it goes up to /Users/Shared
I will check the same in a macintel later.
> OK,
> So here is further weirdness.
> Michael
> I get an error message and no GUI for gisdbase selection on my old
G4 in the
> lab.
relatively
> new Intel Mac laptop
> I get an error message, but ALSO GET A GUI for gisdbase selection on
my G5
> desktop (ca. 2 years old). All are uptodate with software and running
> current versions of GRASS 6.3.
> Here is what I get on the G5--which is what everyone ought to get.
> Set an invalid gisdbase in .grassrc6
> Start with tcltk interface
> Terminal:
> ERROR: LOCATION << /Users/Shared/grassdata9/spearfish60_test >> not
> available
> TclTk warning box:
> "WARNING: Invalid Database
> Warning Invalid database. Finding first valid directory in parent tree"
> Click OK
> TclTk warning box
> "WARNING: invalid location
> Warning: location <locname> at GISDBASE <gisdbase> is not a directory or
> does not exist.
> Click OK
> Choose valid gisdbase, location, and mapset from TclTk GUI
> Start GRASS OK.
> Start with wx (wxgrass) and there is a long terminal error, so this
is not
> being checked there.
> Michael
> On 5/29/07 12:30 PM, "William Kyngesburye" <woklist at kyngchaos.com>
wrote:
> > On May 29, 2007, at 1:54 PM, Michael Barton wrote:
> >> Always as far as I remember. Change the name of your location or
> >> move it,
> >> for example, and you get an error at startup. The only way to fix
> >> it is to
> >> edit your .grassrc6
> > Likewise here the other way - that is, as long as I can remember it's
> > always given the error, then gone into the mapset selection anyways.
> > Though there is another problem I DO have - if the location or mapset
> > is invalid, I can't create a new location by values in the GUI -
> > clicking Define new location with projection values button in the GUI
> > gives me (the good db name is 'grassdb'):
> > ERROR: LOCATION << /Users/kyngchaos/Documents/gis/grassdbz/
> > spearfish60 >>
> > not available
> > while executing
> > [previous error message repeated a few times]
> > "exec -- $env(GISBASE)/etc/grass-xterm-wrapper -name xterm-grass -e
> > $env(GISBASE)/etc/grass-run.sh $env(GISBASE)/etc/set_data"
> > invoked from within
> > ".frame0.frameNMS.seventh.button invoke"
> > ("uplevel" body line 1)
> > invoked from within
> > "uplevel #0 [list $w invoke]"
> > (procedure "tk::ButtonUp" line 22)
> > invoked from within
> > "tk::ButtonUp .frame0.frameNMS.seventh.button"
> > (command bound to event)
> > It doesn't even try to run grass-xterm-wrapper. Even if I correct
> > the DB location in the GUI, I get this error. So it could be related
> > to the problem you're having. It works normally in the text startup.
> >> Maybe, but I've got the same result on different Mac's (PPC and
> >> Intel). My
> >> Intel at least has never had an old version of the OS on it. I always
> >> assumed that this was normal, and have been planning to add an
> >> error trap
> >> into gis_set.tcl for a long time, but hadn't gotten around to it.
> > How about my binary? I recently added a 5/20 CVS build for download
> > on my site.
> >> Note that we just had a report on the GRASS list of someone who had a
> >> similar error on the Mac. Kind of strange.
> > Yeah, saw it, figured that's why you started on the error trapping.
> > It sounded like they were using the old unix build, not a .app
> > build. The only difference is pre-init.sh - where the .app sets some
> > GRASS env var defaults appropriate for the .app.
> > William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> > http://www.kyngchaos.com/
> > Theory of the Universe
> > There is a theory which states that if ever anyone discovers exactly
> > what the universe is for and why it is here, it will instantly
> > disappear and be replaced by something even more bizarrely
> > inexplicable. There is another theory which states that this has
> > already happened.
> > -Hitchhiker's Guide to the Galaxy 2nd season intro
> __________________________________________
> Michael Barton, Professor of Anthropology
> School of Human Evolution & Social Change
> Center for Social Dynamics and Complexity
> Arizona State University
> phone: 480-965-6213
> fax: 480-965-7671
> www: http://www.public.asu.edu/~cmbarton
> grass-dev mailing list
> grass-dev at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass-dev
Dr. Agustín Diez Castillo
Departament de Prehistòria i Arqueologia
Universitat de València Phone: +34 963 86 42 42
Avda. Blasco Ibañez, 28 Fax: +34 963 86 42 34
València 46010
