[GRASS-dev] Re: [grass-code I][412] v.in.ascii: fails if data in last column is all empty
Martin Landa landa.martin at gmail.com
Wed May 30 09:27:36 EDT 2007
it is strange but I cannot attach patch using GForge. I add the file
to 'Attach Files', click to 'Submit'. Then I can see 'Updated
successfully' but in the result 'No Files Currently Attached'. Maybe I
am doing something wrong, in the past I remember that it worked. So
there is the patch...
Martin
2007/5/30, grass-codei at wald.intevation.org <grass-codei at wald.intevation.org>:
> code I item #412, was opened at 2007-05-30 12:34
> Status: Open
> Priority: 3
> Submitted By: Hamish Bowman (hamish)
> Assigned to: Martin Landa (martinl)
> Summary: v.in.ascii: fails if data in last column is all empty
> Issue type: module bug
> Issue status: None
> GRASS version: CVS HEAD
> GRASS component: vector
> Operating system: all
> Operating system version:
> GRASS CVS checkout date, if applies (YYMMDD): 070529
> Initial Comment:
> v.in.ascii fails if data in last column is all empty:
> v.in.ascii out=test_via \
>   column='x double, y double, name varchar(3), other int' << EOF
> 11|21|abc|
> 12|22|def|
> 13|23|ghi|
> 14|24|jkl|
> 15|25|mno|
> EOF
> Scanning input for column types ...
> Maximum input row length: 11
> Maximum number of columns: 3
> Minimum number of columns: 3
> column: 1 type: integer
> column: 2 type: integer
> column: 3 type: string length: 3
> WARNING: Table 'test_via' linked to vector did not exist.
> ERROR: Number of columns defined (4) does not match number of columns (3)
>        in input.
> 3x dirsep = 4 columns.
> Currently need a kludge in v.in.gpsbabel and v.in.garmin to work around this.
> Exists in GRASS 6.0.2 - latest 6.3 CVS.
> Hamish
> >Comment By: Martin Landa (martinl)
> Date: 2007-05-30 15:23
> Message:
> missing patch...
> Date: 2007-05-30 15:21
> Message:
> This patch should fix the problem. Please test it.
> You can respond by visiting:
> http://wald.intevation.org/tracker/?func=detail&atid=204&aid=412&group_id=21
Martin Landa <landa.martin at gmail.com> * http://gama.fsv.cvut.cz/~landa *
Type: application/octet-stream
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20070530/98f20d40/token.c.obj
