[GRASS-dev] r.colors now producing bogus color files for 'ryg'
case
Dylan Beaudette
dylan.beaudette at gmail.com
Wed May 30 18:33:16 EDT 2007
On Wednesday 30 May 2007 00:44, Hamish wrote:
> Dylan Beaudette wrote:
> > A colleague of mine just noticed that the command
> > r.colors map=some_map color=ryg
> > the resulting colr file was malformed.
> > This seems to have been introduced fairly recently into CVS.
> works for me, both CELL and DCELL maps. can you provide more info?
> (spearfish)
> G63> r.colors elevation.10m col=ryg # DCELL
> G63> r.info -r elevation.10m
> min=1061.064087
> max=1846.743408
> G63> r.colors elevation.dem col=ryg # CELL
> G63> r.info -r elevation.dem
> min=1066
> max=1840
> G63> cat colr2/PERMANENT/elevation.*
> % 1061 1846
> 1061:255:0:0 1453.5:255:255:0
> 1453.5:255:255:0 1846:0:255:0
> % 1066 1840
> 1066:255:0:0 1453:255:255:0
> 1453:255:255:0 1840:0:255:0
> I notice that the range of the DCELL map is greater than the range of
> its color map, so max values will be shown as the null value color
> (nv white). Something cast to int when it should use ceil(max) and
> floor(min)? How does that work if the data range is 0.0-1.0?
> Hamish
Thanks for the follow-up Hamish. I am rather mystified by this problem myself
as the rules file in '/usr/local/grass-xxx/etc/color/ryg' looks fine. The
dataset that caused this mess ranges from 0.1 - 0.6. Other other color ramps
appear to work fine. The resultant colr file had something like
0%
0:127:0 0:127:0
in it.. I can check again if that looks like it might mean something.
dylan
Dylan Beaudette
Soils and Biogeochemistry Graduate Group
University of California at Davis
530.754.7341
