No subject
Wed Nov 14 13:37:45 EST 2007
> From grass-lists-owner at max.cecer.army.mil Wed Jan 20 05:05:32 1993
> Return-Path: <grass-lists-owner at max.cecer.army.mil>
> From: Darrell McCauley <mccauley at ecn.purdue.edu>
> Sender: mccauley at ecn.purdue.edu
> Sender: lists-owner at max.cecer.army.mil
> Reply-To: grassu-list at max.cecer.army.mil
> In-Reply-To: <01GTPO6372W294DT5E at icil64.cilea.it>
> Subject: multi-user Configuration Setup
> X-Lines: 70
> ask each user to do the following:
> install -d ~/grass/data # or something appropriate
> cd ~/grass/data
> foreach location (/mcae/grass.data/*)
> if (-d $location) then
> mkdir $location
> cd $location
> foreach mapset ($location/*)
> if (-d $mapset) ln -s $mapset
> end
> cd ..
> endif
> end
> Then, when they run grass, have them put their own directory
> name when it asks for a DATABASE (e.g. /home/icil64/joe_user/grass/data).
> The set of csh commands given above untested, but I think that you
> can get the jist of what's going on. Try it out, package it up in a
> shell script, and have each new grass user run it (maybe you could
> even put a hook in GIS.sh to check for the existence of ~/.grassrc
> to do this... oh, one is already there. just modify it:
> | if [ ! -f $GISRC ]
> | then
> set_up_stuff_for_icil64.csh # make users use their home dir for data
> | cat $ETC/gis_intro
> | echo ""
> | echo "Hit RETURN to continue"
> | read ans
> | fi
> --Darrell
> MINOJA at icil64.cilea.it (MINOJA at icil64.cilea.it) writes on 19 Jan 93:
> > Hello Grass User,
> > On my machine as root user I have installed grass4.0 using this
> > SETUP configuration.
> > ARCH = Convex10.0
> > GISBASE = /mcae/GRASS/Convex10.0
> > UNIX_BIN = /mcae/GRASS/bin
> > DEFAULT_DATABASE = /mcae/grass.data
> > DEFAULT_LOCATION = spearfish
> > This configuration is not good for me because every grass user may write
> > own data into the disk /mcae.
> > I wish to configure SETUP in a such way so as my users for default write
> > data into own home directory.
> > Note that into /mcae/grass.data I have the grass demo files and I wish
> > that my users are able to read (read only!) this information.
> > Thank You very much
> > Bruno
>______________________________________________________________________________
> >Bruno Minoja
> >Cilea (Consorzio InterUniversitario Lombardo Elaborazione Automatica)
> >Via R. Sanzio 4
> >Segrate Milano Italia
> >E_MAIL : minoja at icil64.cilea.it
__ L Dr Simon Cox
,~' L_|\ VIEPS Department of Earth Sciences,
,-' \ Monash University, Clayton Vic 3168
( soon \ Australia
X<~~~~~~~~~ / Phone +61 3 905 5762
L,~' "\_x/ Fax +61 3 905 5062
u simon at artemis.earth.monash.edu.au
