No subject
Wed Nov 14 13:37:45 EST 2007
"CODE OPTIMIZATION
If you would like to set compiler optimisations, for a possibly faster
binary, type (don't enter a ";" anywhere):
        CFLAGS=-O ./configure
or,
        setenv CFLAGS -O
        ./configure
whichever works on your shell. Use -O2 instead of -O if your compiler
supports this (note: O is the letter, not zero). Using "gcc" compiler, you
can also specify processor specific flags (examples):
  CFLAGS="-mcpu=k6 -O2"     # AMD K6 processor
  CFLAGS="-mcpu=pentium"    # Intel Pentium processor
  CFLAGS="-mcpu=pentiumpro" # Intel PentiumPro processor
  gcc -dumpspecs
So you can use
    CFLAGS=-O2 ./configure
    make
    make install
Hope this helps,
 Markus
