No subject
Wed Nov 14 13:37:45 EST 2007
to use the Matrox provided driver, the Xfree glx is slightly faster.
> I use the stock XFree86 glX module without DRI, so Mesa is used for
> the rendering. It isn't particularly fast, but at least it doesn't
> crash the system so hard that not even Alt-SysRq-* work.
With DRI disabled and glx enabled the result is twice as fast as
with both disabled (try "gears"), better than nothing...
> A suggestion regarding NVIZ bug reports: ask the user to post the
> output from "glxinfo", and check that it contains:
> OpenGL renderer string: Mesa GLX Indirect
> If it doesn't, tell them to try using the stock XFree86 glX module
> without DRI, and see if the problem persists. If it does, we have a
> problem. If it goes away, it's yet another failed attempt at OpenGL.
Yes, confirmation that this is working:
glxinfo |grep "OpenGL\|glx"
server glx vendor string: SGI
server glx version string: 1.2
server glx extensions:
client glx vendor string: SGI
client glx version string: 1.2
client glx extensions:
OpenGL vendor string: VA Linux Systems, Inc.
OpenGL version string: 1.2 Mesa 3.4
OpenGL extensions:
This is working on Redhat7.1 with Xfree 4.0.3 and nviz and Matrox G450.
Today I'll try Xfree 4.1.0. Maybe a new chance for DRI?
Later,
Markus
