No subject
Wed Nov 14 13:37:45 EST 2007
transformed from GRASS 5.0.1 (the codes are not in a
clear style, but can run).
http://nadss.unl.edu/grasslib.tar.gz
Currently, what we did are first find what the GRASS
commands we need in our component function calls; then
we transformed the GRASS commands to the library
function in a shared library. Since original GRASS
commands were existing the memory leak problems (they
are ok for process based command, however, bad for a
library function call), so we try to find theose leak
and repaired them.
The transformation work is sitll under process; we are
glad to hear from other people who do the similar
work.
Shifeng
__________________________________
Do you Yahoo!?
SBC Yahoo! DSL - Now only $29.95 per month!
http://sbc.yahoo.com
