No subject
Wed Nov 14 13:37:45 EST 2007
On Thu, Aug 21, 2003 at 12:18:33PM +0100, Glynn Clements wrote:
> Note that the g.select.pg program in 5.0.2 (and earlier) doesn't allow
> you to "undefine" a host. Once you use "g.select.pg host=...", all
> subsequent connections will be via TCP/IP. You can select a different
> host, but you can't revert to Unix domain sockets.
> To revert to using a Unix domain socket to connect to a local
> postmaster process, you have to manually delete the PG_HOST entry from
> the $GISRC file (typically ~/.grassrc5).
> This is fixed in the CVS HEAD version, and should be fixed in 5.0.3.
Is this already fixed in 5.0.3? Where to look for that?
Markus
