No subject
Wed Nov 14 13:37:45 EST 2007
future.
> > My purpose was to check, if thuban and/or mapserver can read
> > GRASS-imported PostGIS-data, but I failed, because geometry-type
> > LINESTRING is not (yet) supported by thuban.
> > I realised, that the geometry-column in roads_geom is only called
> > 'geom', but imported data via shp2pgsql results in a geomtry-column
> > named 'the_geom'.
> That is OK, there is no rule for geometry column name, AFAIK.
> > BTW, it would be nice to rename the 'geom'-column into 'the_geom' to
> > use postGIS-query's from mapserver more intuitively.
> For me, it would not be nice, 'the_' is not any information, it is
> only longer.
RIght, no more information provided with this...
> > also no entry in the table geometry-columns was made... but maybe I
> > had not granted this table for update/insert by this postgres user
> > to write an entry...
> Yes, GRASS should add record to geometry_columns.
agreed
cheers
Stephan
Stephan Holl
GnuPG Key-ID: 11946A09
10:59:20 up 2:33, 1 user, load average: 0.10, 0.08, 0.02
--Signature=_Fri__3_Oct_2003_11_10_53_+0200_r+1V+napRtSQfQKB
Content-Type: application/pgp-signature
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.2.2 (GNU/Linux)
iD8DBQE/fT0gEg9SKhGUagkRAscWAKCtvDOoej8k/SoYcm+ezQVwxo1eDACeLzFK
Kf4kDBcgsQCtRbXSDIr9wUI=
=iu7E
-----END PGP SIGNATURE-----
--Signature=_Fri__3_Oct_2003_11_10_53_+0200_r+1V+napRtSQfQKB--
