No subject
Wed Nov 14 13:37:45 EST 2007
> >However, if we use a separate untar utility (or tar), it seems to
> >uncompress
> >and expand fine. He is going to go ahead and install it manually.
> >Is there perhaps a problem with the shell script? In line 24
> >TAR_FILE_SIZE=41899191
The shell script is ok, I think:
[grass.itc.it]
bash-2.04$ cd binary/mswindows_cygwin/
bash-2.04$ l
total 44288
-rw-rw-r-- 1 neteler grass 9149 Jun 24 16:23 grass-5.7.0-i686-pc-cygwin-24_06_2004-install.sh
-rw-rw-r-- 1 neteler grass 41899191 Jun 24 16:28 grass-5.7.0-i686-pc-cygwin-24_06_2004.tar.gz
bash-2.04$ grep 41899191 grass-5.7.0-i686-pc-cygwin-24_06_2004-install.sh
bash-2.04$ pwd
/hardmnt/grass0/neteler/www/grass57/binary/mswindows_cygwin
So that looks ok. Maybe MS-Windows has a different idea of bytes?
> Change that number to the size of the file in bytes (check with ls -l) if
> you're sure it downloaded correctly. Or just delete the lines in the
> installation script that check the file size.
Up to now it always worked.
Markus
