No subject
Wed Nov 14 13:37:45 EST 2007
- Variable: CFLAGS
Debugging and optimization options for the C compiler. If it is
not set in the environment when `configure' runs, the default
value is set when you call `AC_PROG_CC' (or empty if you don't).
`configure' uses this variable when compiling programs to test for
C features.
- Macro: AC_PROG_CC ([COMPILER-SEARCH-LIST])
[snip]
If using the GNU C compiler, set shell variable `GCC' to `yes'.
If output variable `CFLAGS' was not already set, set it to `-g
-O2' for the GNU C compiler (`-O2' on systems where GCC does not
accept `-g'), or `-g' for other compilers.
> Manually resolved, now recompiled from scratch.
> (gdb) r -anC input='areecampione125m,modis_vi250m20010712.250m_16_days_EVI' fs=space
> Starting program: /hardmnt/eden0/ssi/software/cvsgrass61/dist.x86_64-unknown-linux-gnu/bin/r.stats -anC input='areecampione125m,modis_vi250m20010712.250m_16_days_EVI' fs=space
> Detaching after fork from child process 6288.
> Detaching after fork from child process 6289.
> WARNING: r.stats: cats for modis_vi250m20010712.250m_16_days_EVI are either
> missing or have no explicit labels. Using nsteps=255
> Program received signal SIGSEGV, Segmentation fault.
> 0x0000000000402b7f in main (argc=4, argv=0x7fbffff498) at main.c:242
> 242 for (i = 0; name = option.cell->answers[i]; i++)
> (gdb) bt full
> #0 0x0000000000402b7f in main (argc=4, argv=0x7fbffff498) at main.c:242
> i = 2
> option = {cell = 0x3535323d737065, fs = 0x508730, nv = 0x5087c0, output = 0x508850, nsteps = 0x508900}
> This looks similar (but hopefully more reasonable) to the first
> report.
That option.cell == 0x3535323d737065 looks quite wrong. The fact that
i == 2 suggests that it didn't start out wrong but has been
overwritten, apparently with ASCII:
$ echo -ne 'eps=255\0' | od -t x8
0000000 003535323d737065
Hmm.
char msg[100];
sprintf(msg, "%s: cats for %s are either missing or have no explicit labels. Using nsteps=%d", G_program_name(),name, nsteps);
Assuming:
G_program_name() = "r.stats"
name = "modis_vi250m20010712.250m_16_days_EVI"
nsteps = 255
gives:
msg = "r.stats: cats for modis_vi250m20010712.250m_16_days_EVI are either missing or have no explicit labels. Using nsteps=255"
The backtrace says:
msg = "r.stats: cats for modis_vi250m20010712.250m_16_days_EVI are either missing or have no explicit label"
which is 100 bytes. The remainder ("s. Using nsteps=255" and the
terminating NUL) is beyond the array, and the last 8 bytes
("eps=255\0") are overwriting option.cell.
I suggest getting rid of all of the sprintf() calls and just using
G_fatal_error() (which has a 2000 byte buffer).
