[GRASS-dev] Wingrass and TclTk
Benjamin Ducke
benjamin.ducke at ufg.uni-kiel.de
Thu Nov 1 08:14:07 EDT 2007
> wms.download and wms.request are internal from scripts/r.in.wms/
> missing:
> mpeg_encode or ppmtompeg for r.out.mpeg
There are several mpeg encoders with a binary called mpeg_encode around.
Which one is the one we need, specifically?
Is ppmtompeg the one that comes with the NetPBM tools?
> some of the above are optional
> (d.polar will work without xgraph, r.in.wms will work without xml2)
> curl & wget are either/or
> gardump & gpstrans are either/or and probably UNIX,Linux specific, respectively
> GpsDrive is not ported to MS Windows so d.out.gpsdrive deps are low priority
> All the C system() calls need to be searched too I guess.
>> BTW, the use of "ldd" by v.in.wfs is entirely bogus:
>> # xerces support compiled in?
>> OGRINFO=`which ogrinfo`
>> if [ -z "`ldd $OGRINFO | grep xerces`" ] ; then
>> g.message -e "OGR needs to be compiled with xerces-c support"
>> exit 1
>> fi
>> This needs to be changed to something which will work on other
>> platforms. Does "gdalinfo --formats" suffice?
As far as the Win binaries are concerned: why not just ship them with
Xerces support in GDAL?
>> Also, we don't really need all three of lynx, wget and curl; any one
>> of those would suffice.
> IIRC lynx is used to strip off HTML tags, ie to convert .html to .txt.
> r.in.wms (wms.download) checks for wget. If it can't find it it then looks for
> curl. (Apparently curl comes with MacOSX but wget doesn't)
That's correct (at least for Mac OS 10.4 as far as I can tell).
Both are tiny little things, though, so how much harm
would it do to pack them both?
> So we wouldn't want to supply both.
> Hamish
> __________________________________________________
> Do You Yahoo!?
> Tired of spam? Yahoo! Mail has the best spam protection around
> http://mail.yahoo.com
Benjamin Ducke, M.A.
Archäoinformatik
(Archaeoinformation Science)
Institut für Ur- und Frühgeschichte
(Inst. of Prehistoric and Historic Archaeology)
Christian-Albrechts-Universität zu Kiel
Johanna-Mestorf-Straße 2-6
D 24098 Kiel
Germany
Tel.: ++49 (0)431 880-3378 / -3379
Fax : ++49 (0)431 880-7300
www.uni-kiel.de/ufg
