[GRASS-dev] Wingrass and TclTk
Glynn Clements
glynn at gclements.plus.com
Thu Nov 1 09:46:06 EDT 2007
Hamish wrote:
> All the C system() calls need to be searched too I guess.
And popen(), and G_{system,popen,spawn,spawn_ex}.
> > BTW, the use of "ldd" by v.in.wfs is entirely bogus:
> > # xerces support compiled in?
> > OGRINFO=`which ogrinfo`
> > if [ -z "`ldd $OGRINFO | grep xerces`" ] ; then
> > g.message -e "OGR needs to be compiled with xerces-c support"
> > exit 1
> > fi
> > This needs to be changed to something which will work on other
> > platforms. Does "gdalinfo --formats" suffice?
> Nope.
> $ ogrinfo --formats | grep -ic xer
> 0
> $ ldd `which ogrinfo` | grep xer
> libxerces-c.so.27 => /usr/lib/libxerces-c.so.27 (0xb76c0000)
> as Xerces is apparently a XML parser not a vector format :)
> You could try
> $ gdal-config --dep-libs | tr ' ' '\n' | grep -ci xerces
> 1
> but then gdal-config isn't always around. e.g. on Debian gdal-config comes with
> the libgdal1-dev package and not the gdal-bin package. (and the libgdal1-dev
> package depends on 18 other dev packages, which in turn depend on enough stuff
> to make it a 20-50mb download just to run gdal-config. :-/ )
And it still won't show anything if xerces is linked statically into
libgdal.
I suspect that the only real solution is to simply try it.
> > Also, we don't really need all three of lynx, wget and curl; any one
> > of those would suffice.
> IIRC lynx is used to strip off HTML tags, ie to convert .html to .txt.
But it's supposed to be saving an XML file:
lynx -dump "$WFS_URL" > "$TMP.xml"
