[GRASS-dev] Re: projshare path
Glynn Clements
glynn at gclements.plus.com
Thu Nov 1 22:21:40 EDT 2007
Paul Kelly wrote:
> > Another issue with paths:
> > For configure I have to give the location of the proj share directory in
> > *nix path form (/c/grass/share/proj/).
> > However, this won't work at runtime. So we need to translate PROJSHARE
> > from one to the other before putting it into init.bat.
> It might be better for the configure script to accept it in the proper
> format rather than trying to translate later??
Then the configure script has to translate it to MSys' syntax perform
the existence checks.
