[GRASS-dev] Re: need a truly quiet quiet
Michael Barton
c.michael.barton at gmail.com
Fri Nov 2 00:38:50 EDT 2007
On Nov 1, 2007, at 5:49 PM, grass-dev-request at grass.itc.it wrote:
> Initial Comment:
> Hi,
> I have just experienced, how expensive it can be, to write a
> WARNING out for every point, when buffering. I try to build simple
> buffers (only 8 points needed) around a lot of points - in one case
> 370.000 - and for the reason I choose a high tolerance value (to be
> sure, it will be reset to the max allowed one). THis works, but
> takes unbelievably long with all the warnings:
> "WARNING: The tolerance was reset to ..."
> Now I have commented out the warning in main.c of v.buffer, and
> suddenly it is running like mad (30 seconds instead of over 10
> minutes). So maybe it would be nice to :
> - either add another switch to turn off this warning
> - or include it under the "--quiet" option (NO warning if "--quiet"
> set).
> Andras Fabian
> You can respond by visiting:
> http://wald.intevation.org/tracker/?
> func=detail&atid=188&aid=525&group_id=21
Andras,
I really really agree with you. This has been an endless source of
problems for me trying to script a GUI around modules that will not
be quiet.
Michael
____________________
C. Michael Barton, Professor of Anthropology
Director of Graduate Studies
School of Human Evolution & Social Change
Center for Social Dynamics & Complexity
Arizona State University
Phone: 480-965-6262
Fax: 480-965-7671
www: <www.public.asu.edu/~cmbarton>
URL: http://lists.osgeo.org/pipermail/grass-dev/attachments/20071101/bdc0b65a/attachment.html
