[GRASS-dev] r.li lib name
Glynn Clements
glynn at gclements.plus.com
Sun Nov 4 04:35:39 EST 2007
Markus Neteler wrote:
> >> Building CVS today (last build a couple weeks ago). I'm getting a
> >> liblibr_li. I remember this from quite a while ago, but I thought it
> >> was fixed (ie renamed). I could also have just forgotten about it and
> >> noticed again just now.
> > It hasn't changed since:
> > revision 1.2
> > date: 2006/11/21 22:41:06; author: markus; state: Exp; lines: +8 -13
> > Serena Pallecchi/Faunalia: various fixes; r.li lib now shared lib
> In general, if such thing is known and easy to fix and original author
> absent, why not just fixing it rather than populating bug tracker and
> mailing list? Or is it complicated?
Because different people have different ideas regarding what is or is
not a bug. None of the things mentioned in the bug tracker entry are
unambiguous bugs or have an obvious unique "solution".
