wingrass: launching gui and shell [was: Re: [GRASS-dev] Wingrass and TclTk]
Sun Nov 4 04:45:18 EST 2007
Moritz Lennert wrote:
> > The command prompt in GRONSOLE works to run all GRASS modules and scripts
> > EXCEPT those that require an interactive (e.g., curses) xterm interface.
> > There aren't many of these left and only some of those will run well in
> > Windows I suspect. It will also run Unix commands (many unavailable in
> > Windows anyway) that don't require an interactive response (e.g., ls, cat,
> > etc). Beyond the interactive part, I'm not sure why some people think it is
> > so limited. It is designed to be a GRASS terminal, not a general purpose,
> > everything Unix terminal.
> The enourmous advantage of using the command line for grass is the
> almost unlimited capacity to mix grass commands with others or just to
> be able to combine different grass commands. The scripts in the scripts
> directory are a perfect example of such combination.
> I know I can use the gronsole prompt to type in grass commands, but this
> is only a very small part of the added value of the command line. I know
> I can use some other shell commands on the gronsole, but it's not easy
> to combine them into scripts and ISTR that the commands you can use are
> limited (e.g. can you run a 'for * in g.mlist' type of loop ?).
Those commands aren't run via a shell, so you can't use any shell
built-ins or syntax, unless you explicitly run "sh -c ...". Even then,
each command is run as a separate child process, so there's no
persistence of state between them.
