[GRASS-dev] Re: GRASS documentation
Michael Barton michael.barton at asu.edu
Mon Nov 5 10:00:50 EST 2007
Thanks very much. This is a good guideline. This is a place where a doc
coordinator could put this on the WIKI.
Michael
On 11/5/07 5:10 AM, "Glynn Clements" <glynn at gclements.plus.com> wrote:
> Michael Barton wrote:
>>> 1. They must not contain tags or entities which are not understood by
>>> the g.html2man script (tools/g.html2man/g.html2man).
>> Can you or someone specify what these are?
> From a brief look at the g.html2man source, the following all appear
> to be understood to some extent:
> <A> <B> <BLINK> <BODY> <BR> <CODE> <DD> <DL> <DT> <EM> <H2> <H3> <H4>
> <HEAD> <HEADER> <HR> <I> <IMG> <LI> <OL> <P> <PRE> <SUP> <TABLE> <TD>
> <TH> <TITLE> <TR> <UL>
> However, g.html2man just uses regexp matching; it doesn't include a
> proper HTML parser. Consequently, there will be other restrictions on
> the precise format, e.g. I wouldn't expect line breaks between
> attributes to work.
>>> 2. Any portions which are not modified must not be re-formatted during
>>> the editing process, as this will make the output from "cvs diff"
>>> useless.
>> Maybe one way to do this is to work with a copy of the description.html
>> file, then use a simple text editor to cut out the edited/enhanced section
>> and paste it into the original--leaving other areas untouched.
>> However, any significant changes, including adding images, could put a bunch
>> of stuff into a cvs diff.
> If there are many "genuine" changes, then you would expect to see a
> substantial diff. The point is that changes shouldn't result in excess
> diff output because unchanged sections have been reformatted (or
> rather, regenerated) by the editor.
Michael Barton, Professor of Anthropology
Director of Graduate Studies
School of Human Evolution & Social Change
Center for Social Dynamics & Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
