[GRASS-dev] select issue with wingrass
Michael Barton
michael.barton at asu.edu
Tue Nov 6 10:18:58 EST 2007
Glynn,
I agree that it certainly looks like the problem code is
glob -nocomplain $path/*
"glob" ought to work because it is pure TclTk in this case (although
identical to the unix command). What about the "*"?
I don't know how to test this on Windows. Suggestions?
Michael
On 11/6/07 2:55 AM, "Glynn Clements" <glynn at gclements.plus.com> wrote:
> The relevant code is:
> # main selection subroutine
> if {$element != "symbol"} {
> foreach dir [exec g.mapsets -p] {
> set windfile "$location_path/$dir/WIND"
> if { ! [ file exists $windfile ] } { continue }
> if { $dir == $current_mapset } {
> $tree insert end root ms_$dir -text $dir -data $dir -open 1 \
> -image [Bitmap::get openfold] -drawcross auto
> } else {
> $tree insert end root ms_$dir -text $dir -data $dir -open 0 \
> -image [Bitmap::get folder] -drawcross auto
> set path "$location_path/$dir/$element/"
> foreach fp [ lsort [glob -nocomplain $path/*] ] {
> set file [file tail $fp]
> $tree insert end ms_$dir $file@$dir -text $file -data $file \
> -image [Bitmap::get file] -drawcross never
> The "file exists $windfile" test is obviously working, otherwise he
> wouldn't see the mapsets. The most likely problem is with the "glob"
> command. The glob(n) manpage implies that / should work. Can you try
> running tclsh/wish interactively and testing the behaviour of the glob
> command?
Michael Barton, Professor of Anthropology
Director of Graduate Studies
School of Human Evolution & Social Change
Center for Social Dynamics & Complexity
Arizona State University
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
