[GRASS-dev] i.rectify should test for illegal file names before
launching rectification
Moritz Lennert
mlennert at club.worldonline.be
Tue Nov 6 10:57:25 EST 2007
On 06/11/07 16:27, Michael Barton wrote:
> Sorry to be dense, but an *optioal* argument *must* be present in i.rectify,
> even if it is empty? This seems like a very weird situation.
It is not optional.
This is not an issue in gis.m from where you cannot call i.rectify
anymore (you have to go through the georectifying tool) .You can try it
by typing i.rectify at the command line. In the tcltk window that pops
up, just type any bogus values into all fields except for extension. If
you click on run, you will get the error message:
ERROR: Required parameter <extension> not set:
(Output file extension (inputfile(s) + extension)).
But in my case I don't want an extension, or, said differently, I want
the extension to be empty. At the command line, I can just type
'extension=', but there is no way I can give an 'empty' value to the
extension parameter in the tcltk gui.
> To do it in TclTk, I'd do it one of two ways, depending on which execution
> procedure you are using.
> You could just put the whole command in quotes as a string.
> set cmd "i.rectify ... extension="
> [parse and run] cmd
> OR
> You could put the command in a list and parse it that way.
> set cmdlist [list "i.rectify" "arg1" "arg2" ... "extension="]
> [parse and run] cmdlist
So this means we have to change g.parser as Glynn seems to suggest,
especially if this concerns other modules as well.
Moritz
