[GRASS-dev] select issue with wingrass
Fri Nov 9 19:00:17 EST 2007
> >>>> ERROR 4: Unable to open EPSG support file gcs.csv.
> >>>> Try setting the GDAL_DATA environment variable to point to the
> >>>> directory containing EPSG csv files.
> >>> Have you tried setting this ?
> > Try setting it in the grass63.bat file:
> > set GDAL_DATA=
> You mean leave this blank/empty? Or do you mean to point this variable to a
> valid location?
point it to the relevant C:\... path
> > But is this a GRASS variable or a GDAL variable ?
> I have absolutely no idea.
it is an enviroment variable used by GDAL.
Hamish
__________________________________________________
Do You Yahoo!?
Tired of spam?  Yahoo! Mail has the best spam protection around
http://mail.yahoo.com
