[GRASS-dev] select issue with wingrass
Glynn Clements
glynn at gclements.plus.com
Mon Nov 12 06:14:56 EST 2007
Michael Barton wrote:
> It appears that r.mapcalc is NOT working. We get an error with even the
> simplest of mapcalc statements. Javi will send the error message tonight or
> tomorrow, but it is a red herring IMHO, stating that it is missing an "=".
> We have the same error if we run r.mapcalc via the TclTk interface
> (r.mapcalculator) or run it from the console command line. Other commands
> work find from the console command line. This is *critical*, of course, as
> r.mapcalc is very important to GRASS analysis and map management.
FWIW, the only r.mapcalc files which have changed in the last three
months are:
Makefile
map3.c
r.mapcalc.html
r3.mapcalc.html
The Makefile changes were part of the parallel build effort, and don't
change what is compiled or which switches are used. The map3.c changes
are just standardisation of messages, and only affect r3.mapcalc.
I presume that this is related to your local environment; otherwise, I
would expect to see other people reporting it.
